willl it interchange
kracker
i bought a charging,ignition,harness online. it has a stator#398-9873-a3 i know the trigger will work and the switch boxes. the stator that came off my power head is a #3975454-a34 wil they interchange thanks to all
kracker
lots of lookers but no takers any help out there
well may i didn't give everyone enough info,a 78 black max with a red flywheel that had no spark on 5 and 6 the encapsultion was melted out of the boxes on the bottom of both and the trigger too. so i found a charging system off a 90 150 xr4 II magnum put the boxes and trigger in and fixed my spark problem and using my stator #398-5454-a34. the parts off the rx4 have a stator that looks the same except the two pick up's at the back are closer togather #398-9873-a3 will they interchange or what is difference one a 9amp the other a 16amp or a 40amp the 398-9873-a3 has the same wires as the other i just dont want to melt anything down!!!!! tryed to send pic it said they were to big any help will help the boat runs great on the muffs and will empty the barrel in gear and i hammer it just want to know if i can use the 9873-a3 as a back up!
Fun Times
Re: lots of lookers but no takers any help out there
Kind of hard to tell what the difference between the two really is from the website, they both fit V6's. If by chance no one else can help with this question, your next best bet would be to call CDI to see if they can help. They know their stuff well.;)
Here is the link to both your stators. Find both CDI part numbers listed below and click on the PDF file to see if that helps. If not, try calling Technical Support @ 1-866-423-4832.
http://www.cdielectronics.com/Products.aspx?Criteria=1E2
You're part number, 398-5454A34
CDI Part Number: 174-5456-16
Name: MERCURY STATOR/16 AMP/6 CYL
Install Sheet: 174-5456-16.pdf
Replaces: 174-5456-16 18-5860 18-5871 9-25504 9-25508 398-5454A11 398-5454A15 398-5454A16 398-5454A30 398-5454A31 398-5454A32 398-5454A34 398-5454A35 398-5454A36 398-5454A55 398-5454A61 398-5454A64
You're part number 398-9873-a3,
CDI Part Number: 174-9873-16
Install Sheet: 174-9873-16.pdf
Replaces: 174-9873-16 18-5867 398-9873A36 398-9873A39 398-9873A 1 398-9873A 3 398-9873A 4
Good luck.:)
