Winch strap bending crossbolt
Florida
How do install the winch strap?
Do I loop the strap over the spool of the winch wheel or do I run the cross bolt through the loop in the strap? Either way the cross bolt ends up bent and ready to give out. These arent my pictures but this is what the bolt looks like.
cpubud
Re: Winch strap bending crossbolt
the bolt goes thru the strap eyelet but you need a case hardened bolt to prevent it from bending.
Florida
Thanks for the help. Funny how the manufacturer doesnt provide the right bolt.
jeeperman
If it is an original bolt in the winch, then your overloading the winch.
Ayuh,... It'll bend, but Never break,.... Don't worry about it...
woosterken
Ayuh, .... that dosent make since!!!
if it bends that much, it could pull the sides in and rub the gears
maybe like was mentioned, it is over loaded , move up a size or two in wench size
woosterken
robert graham
Sounds like you're putting a lot of muscle on that winch, maybe review your launch/retrieval procedure before something gets broken! Good Luck!
four winns 214
>>it is over loaded <<
I'm certainly no expert on this subject, but when I replaced the original strap on my trailer's OEM Fulton winch, the strap bolt was bent just like the one in the picture. This trailer was made by the boat's manufacturer for my specific vessel. I can't imagine that they wouldn't use a winch capable of the load.
paultjohnson
Ditto.....and or you must have a short winch strap. I think i rarely use more then about a third of my strap and that bolt rarely sees any tension at all. as prev suggested get one of those hardned [dark colored bolts] You WONT bent that sucker......
DaveJ50
Does anyone know why they don't drill the bolt hole closer to the center so the bolt and strap can actually start at the bottom of the spool?
I always wondered about this.
paultjohnson
I think it helps maintain the spools strength
