Windows
feelinnauti
I have a 1992 sea ray sundancer, iam trying to find help with windows. my port side slide window is broken does anyone no were i can get it fixed or replaced. open for any suggestions!
Thanks feelin nauti
kregars
Re: Windows
Not sure where you are but Budgetboats.net might be able to assist in your search...ebay and craigslist are another place to look.
Re: Windows
Ayuh,... Is it flat glass, or curved plastic,..??
scutly
Re: Windows
call a couple of glaziers for estimates. might not be to pricey. a good glazier can make anything outa glass or plastic and tint to match as well
likalar
Re: Windows
45Auto posts a really good link to Taylor Made: in that link is a sliding window cross-section drawing, of a window a few years after your boat was built. The tough part of the repair is getting someone to do a decent removal and clean installation of the new pane. The rubber gaskets and felts may be weak, or rotted.
the drawing:
http://www.taylormarine.com/hardware/slidingsidewindow.html
rbh
Re: Windows
We replaced the rubbers for our slide windows on our sundancer two years ago as the were hard cracked and leaking, go through taylor made for all your parts if possible, as most marinas/boat shops wont order this stuff in for you, as we found out.
also if you replace the rubber in the track, remember to cut out the space for the drain areas or you will get lots of water inside the boat.:)
rob
45Auto
Re: Windows
As likilar said, that link he posted is for a LATER window with the sliding glass on the INSIDE of the boat. Yours will have the sliding glass on the OUTSIDE of the boat. You'll have to call Taylor Made if you need parts, they're very helpful, you can still get the seals, etc, as RBH said.
