FliesAndFloats
- Sep 6, 2015
- 30
Long story short, I was out in Tampa Bay with my Maxum 2400 SD last weekend cruising along and hit an unusually large wave that hit pretty hard. The bottom screw on the windscreen brace that goes between the curved glass and the flat triangular piece pulled through and left about a 1/4" gap under the glass. This is on the port side that the walkthrough section is hinged to and fortunately the glass appears undamaged, just shifted. The walkthrough's alignment was upset from that as well to where I have to lift up pretty hard to get it to clear to open and close. The bimini top was attached at the time and I think the impact caused a fair amount of leverage against the top aluminum trim piece exerted from the bimini brace and pulled up on it.
It looks like I could probably remove the top section of aluminum from the windshield, reset the glass and put it back together, but I wanted to ask here before doing so in case I was about to find myself involved in a project that was way more difficult than it appears. Is there a source for the trim sections for these windshields or an illustrated parts catalog somewhere that lists this in case I need to find something in the future? I imagine that just about every 24' searay, maxum or bayliner from 2000 on uses the same parts so they've got to be available from somewhere.
Here is a picture of a similar boat. The damage is on my port side. It's the lower screw on that brace that sits between the curved section and the triangular section that came out. There doesn't appear to be any significant damage to the windscreen parts.
