I hate to post this and admit I have absolutely no knowledge however better safe than sorry
It's getting to be that time to winterize and put the boat up for the season and I have no clue what to do!!!!
When I was a kid we had an old 8hp Chrysler at our cabin we would use on the back of the boat, I remember every winter my dad would disconnect the fuel line coming in from our last fishing trip of the year and run it completely out of gas get it off the boat and disconnect the water tube to get any water out of the cylinder(s) and drain out the lower unit... And that was it..
Now years later I have my first boat with a much larger 125Hp Johnson that is older than myself and as I am going through those same steps I am questioning myself as to if these steps will be enough(hoping it's not already too late as it has dropped below freezing a few times already this month)
I disconnected the water hoses there was no water that came out of the cylinders or in the hose I drained the lower unit (going to have to get shaft seals in the spring) and drained the carbs
What else if any should I do
Mike
Mike
