Re: Winterization-Average Cost in Parts and Oil?
NonTox antifreeze.... 10 bucks a gallon.... a 3 liter takes 3ish gallons
Closed cooling? I'm thinking the basic winterization isn't going to include a coolant flush.
Oil.... 2 bucks a quart.... a 3 liter takes 5
$10
oil filter.... 4 bucks for a cheapie..... 7 bucks for a good one
You can get a FRAM, or a Bosch for 4 bucks. You talking about a Mercruiser or something?
$14
gear lube..... 11 bucks a quart.... alpha takes 2
I can get synthetic blended gear lube for about $2.50/quart.
$19
fuel water seperator 10-15 bucks
I got one this summer for $7
$26
stabilizer.... 8 bucks a bottle
There's a Recipe for Sea Foam around here somewhere. You can make 5 gallons of it for less than $20. That's enough to last you a lifetime of winterizations!
Or you can pay $8 per bottle... You're STILL only up to $34...
any other fuel filters $$$
You think they're gonna just GIVE you "any other fuel filters"?
Don't count on it. That's gonna cost you extra. Gurantee you can buy it, and put it on cheaper than they will sell it and install it for...
and then there's the grease, fogging oil, storage seal......
I'll betcha you're going to be paying a surcharge for "shop supplies" as well. The fact is, things like a tube of grease, fogging oil, etc. Are not single-use items. You'll still have PLENTY of grease for future winterizations, as well as to do some periodic lubing during the season... Should be able to fog a few engines with a can of fogging oil as well. Same goes for a can of storage seal...
And that's if you decide not to pull the drive.
So go ahead an pull the drive! It's a $6 gasket.
$40
And if it's due, another $12 for the impeller. How much is the marina gonna charge you for an impeller replacement?
$52
So if i'm at 100 bucks in parts.... bare minimun
Where'd the other $48 go?
Even WITH counting the possible other problems that AREN'T going to be part of your regular winterizaion package, you're not even CLOSE to the $100 mark. Especially if you take my advice, and invest in mixing a bucket of sea-foam, and spread the cost out over the rest of your lifetime!
If it REALLY cost $100 just for parts, how would a marnia even stay in business doing all of that work for just a $50 differential?
You guys are missing steps
and rolling the dice
What steps are we missing? All of those EXTRA steps you mentioned are just that, EXTRA. So when your marina finds that it needs to be done, you're going to be paying EXTRA as well. If you walk in and buy that $150 winterization package, and end up doing all of those 'extras' (which SHOULDN'T be 'extras') after all, you're not going to get out of there for under $300.
See you all with cracked blocks in the spring
I'll see your cracked block, and raise you a new fuel injection system!
