winterization question?
Seaman84
I have a 2004 Glastron sx195 VP 5.0 GL-E & I did all the winterization step.. now the only step I didn't do was Turn the engine over with the starter.. I did disconnect and Drain everything . I filled with Pink RV & Marine AF. Its Garage stored in my warm house & It hasn't been that cold here in Elpaso Texas . it snowed for 2 days staying in temperatures of 27-60 Degrees. Should the block be fine?
Augoose
Re: winterization question?
When you crank the engine for a second you are just getting out any remaining water in the water pump-if you followed the directions and dumped the water out via the two hoses, you should be fine. Not to mention its in a garage anyway
