Re: Winterize 2006 MCM 4.3ltr where are the drain plugs
It's a real problem to tell someone exactly how to drain thier engine without a lot of info, much of it not even shown with the serial number of the engine.
MPI or Carb - Single point, or Multi point drain - engine mounted raw water pump or pump in outdrive - fuel cooler or not?
If you are un-lucky enough to have a single point drain system like Chris has, you will have to remove each hose from the block, manifold, cooler or whatever it's hooked to and make sure the hole isn't plugged up.
