Winterize the seahorse questions
Java_guy23
I read some about winterizing a boat but blowing out water lines didn’t seem to jell with the 63’ super seahorse 40hp. Just got it running a couple days ago and the weather turned extremely cold last night... worried about the engine
No need to worry.-----If stored in the normal running position it drains itself.--------Usually the only damage that can be done is from water INSIDE the gear case .----And the cavities in the gearcase.----Make sure the wee drain holes are clear.
