winterizing 2.5 omc
MooseHootie
1982 renken Does water stay in the lower unit, or just the engine. Does the impeller in the lower unit draw water thru engine or does it have a water pump too ?
Re: winterizing 2.5 omc
The Impeller Pushes water To the Engine.....<br />The outdrive Drains itself when in the Down position.......<br />Don't forget the Hose going from the outdrive To the engine..... You'll see where it goes in through the transom, up-under the motor to the Tstat housing or waterpump......
