bikermikeyblack
- Aug 21, 2011
- 24
mikey
I saw that many have viewed your post but no one wants to reply. To answer your question about winterizing your 2 stroke, I guess it depends on the climate of your region. I live in Western Washington and the winters here are usually mild. I can park my 2 stroke jetski outside under a cover all winter and it will be fine. If you live in a climate in which it gets so cold that it will actually freeze and crack your motor, then perhaps it would be best to bring it in the shed or garage. I do know that many people use a fuel stabilizer called Sta-Bil when winterizing there toys. It works great for winterizing and preserving your fuel for long durations without use. Along that same line, run Sta-Bil in your ski before putting it up for the winter so it will stay in the fuel lines and motor during the winter. Also make sure the fuel tank is completely full when storing it. This makes sure that no condensation can be build up in the tank. I hope this help. Good luck.
Kawasaki doesn't recommend antifreeze for my jetskis... I run stabil year round, fire em up as mentioned above to get water out and also oil the cylinders. They say to remove some of the hoses as part of cleaning for yearly maintenance but I skip that part
