winterizing 2004 VolvoPenta engine
brooksk
Last year purchased new 2004 with 5.0L GL (carbureted) I/O Volvo-Penta engine. I would like to winterize the engine myself this year but have never done an I/O before. The manual speaks of draining and flushing the cooling system at the block and exhaust manifolds but no mention is made of replacing with any kind of anti-freeze as one might do with an automobile engine, etc. Is this not recommended practice for an I/O such as this? Some have suggested putting the raw water intakes in a bucket of anti-freeze and running that through the system. Would the concensus on that? What about fogging the engine?
jaybirdtx
Re: winterizing 2004 VolvoPenta engine
Where you are located it highly recommended that you do a thorough winterization. Volvo water pumps don't pick up as well as Merc, so you'll have to disconnect the main water inlet located at the rear of the engine near the drive shaft, after the engine has ran for a bit and warmed up (allowing the thermostat to open). Rig yourself a funnel or a five gallon jug to get the antifreeze into the engine. Start the engine, make sure it sucks down about 5 gallons of straight antifreeze. Before its all gone, take some trans. fluid or engine fogger and pour in directly into the carb. or intake. Allow it to stall the engine completely out. Don't be alarmed by the smoke this causes, it's normal.
Lou C
The idea of the AF is to provide some corrosion protection as well as insure that any water left in there won't freeze. I have heard of problems using the tank and hose method to suck the AF into the engine, the issue is that for one the impeller must be in really good shape to suck it up (AF has a higher specific gravity than water) and if the thermostat is not open you will not get enough AF in the block. What I do is drain the block, manifolds, etc as per the manual. I then disconnect the big hose from the thermo housing to the circulating pump (big pump on the front of the motor) and the hoses from the thermo housing to the manifolds and impeller. I then fill the manifolds and block until a little AF comes out the drain, thereby displacing any water that was left. I then replace the drain plugs and fill the block thru the big hose I disconnected at the thermo, and the manifolds the same way. I also backfill the line from the impeller till it is full. That way I know all the water is out, and the motor is full of AF (non tox propylene glycol with corrosion inhibitors). I do all this after warming it up on the hose, changing the motor oil, filter and drive oil. Then I run it again to fog the motor, then drain and back fill as above. Oh and BTW, when you remove the drain plugs, run a piece of coat hanger wire up in the drain because they can get blocked by rust flakes, esp on salt water cooled motors.<br />One last caution, when running an engine on the water hose, make sure no one in the house decides to do the wash, or take a shower, it will drop the water pressure enough to overheat the motor! <br />You can run the motor at idle or a little above on the hose but that's it, not enough water volume to cool it at higher speeds.
Scaaty
The first topic at Iboats is the FAQS. Way at the bottom I think is winterization...<br />all you need to know.
4girls
hey lou c, don't you think the fogging agent contaminates your fresh oil change. How come you don't change fluids/clean or change plugs after spring start up ?
