Is this in Oklahoma ??? Isn't it a bit late for winterization?
One thing 'we' have learned from winterization threads is that everyone seems to have their own way of doing it. If you are unsure of the process, it is probably best to consult the service manual for your engine.
What you described is not wrong, but it may not be right enough
MPI engines are typically fogged as per running them for a while with the fogging cocktail as fuel, so I assume you would have to run water for a while, then drain and switch to AF. 5 Gallons of AF isn't much in terms of filling an empty engine.
There are various cooling system flows for the 5.0 MPI . . . got a serial # of the engine to share?
