Scott06
- Apr 20, 2014
- 6,934
2004 vintage carbed 5.0, new to me so this is my first winterization. Has multipoint drain set up so pulled the block drains and manifold drains on both sides plus drain in circulation hose on front- probed the drains with a wire etc.
Question I have is on the intake (Michigan motorz sourced cast iron 4 bbl) looks like there is a plug the might be a water cross over drain just to left of the thermostat- do I need to pull this as well? I'm assuming cross over will drain through heads and block but wanted to bounce this off you all.
Thanks
Thanks
