striper king
- Nov 9, 2003
- 4
This is my first time winterizing an outboard. I have been getting a lot of conflicting info. and advice. it is a 150 hpdi yamaha. Can the motor be run on land with earmuffs? I tried it for only a few seconds but the "pisser" didn't seem to have anything coming out, (didn't want to do any damage). I learned on this site that the engine can't be run with just the flush loop hooked to a hose. (thanx Rodbolt) Should this engine be fogged out or should the oil be sprayed directly into the plug holes? A guy at one boating store parts counter said you cant fog a fuel injected motor because it has no carb- I did not believe that- do you remove the top piece of the intake ? don't these motors have the same internal preservation needs? Vapor canister?
