Re: Winterizing an I/O
On my 140 (older version of 3.0), there are two drains and one petcock. All are on port (left) side of engine (looking forward). You remove brass plugs from the drains. One is on the bottom of the manifold, below and behind the carb. One is on the port side of the riser. The petcock is down below the manifold on the block. You open these after you run the A/F through (you could do it now). You have to poke a wire or tiny screwdriver into each one to make sure it's not clogging, which they do a lot. You want to see A/F, not clear water, coming out of them. Then let them drain. Some people leave them open all winter. Some close them. Other people never even open them, under the theory that they want to keep the A/F in there for the anti-corrosion agents. I personally drain them--I want any clear water pockets out--and then close them. There are even some people who don't use A/F--they just drain their drains, petcocks and hoses. I don't trust that, myself. You really need a manual for your engine to confirm the number and location of drains. It would also show you a lot more. I like the Clymer manual I bought. Lots of pictures. Remember to store the sterndrive in the down position to be nice to your bellows.<br /><br />Steve
