Re: Winterizing article??
That web page has been discussed before.
It's quite silly IMO.
2 cans of fogging oil ??
Anti-freeze ??
The unnamed motors that don't self drain???
Spraying the plugs??
Moisture causes freezing???
Fuel stabilizer prevents freezing??
Add more than is called for?
You should REPLACE the gearcase drain screw gaskets with new ones !!
You are changing the gear lube in fall, so that if it is contaminated with water, it will not freeze and crack the gear case.
Very few people will ever "wear out" the gear lube, as stated.
Don't put the battery on cement??
Forgets to tell you that you should place the battery on a maintainer charger, or charge the battery once a month during storage.
This has proven to lengthen the life of your battery. You should be able to get 6-10 years out of your batteries if well maintained.
If anyone ever poured anti freeze in my bait well or livewell, they would be on the ground holding their jaw.
If they poured it in my bilge, they would be licking it out.
And then there is the OMG amount of grease he put on the prop shaft.
