Winterizing - How much fuel to leave in tank
Massawippi
I really find that there is ton of info on this board and I was wondering if somebdy could help me with this one. <br /><br />This is the first year I've owned a boat and it is getting time to take it out of the water for the winter. Is it better to leave as little gas as possible in the tank or should I leave more?<br /><br />Thanks!
crazy charlie
Re: Winterizing - How much fuel to leave in tank
Fill it up to the point where it will be full but wont come out the vent if tilted a bit.The less room you leave in the tank---the less condensation there will be- and visa versa.Make sure you add stabilizer.Charlie
ZmOz
Yeah, fill it up. Less air means less room for condensation, and the more gas you have, the slower it goes bad. You should use premium though, even if your boat doesn't need it, because as it sits it looses octane.
skategoat
On the other hand, if your gas contains ethanol, the conventional wisdom is to drain the entire system. Ethanol will corrode rubber components including the gas line.
crazy charlie
Skategoat,never heard of draining the entire system before?????? Charlie
POINTER94
Ditto Crazy charlie, and make sure you use a fuel stabilizer in the right amount. <br /><br />ZmoZ I never heard that fuel loses octane, is there a rate that can be measured or is it one of those time/temperature type of things?
crazy charlie
Many people THINK that the fuel looses its octane count because they usually get a ping or unsmoothe running come spring when what it really is ,is that the fuel burns like crap after it has been stabilized.The second tank is always better.Charlie
KM2
I fill it up to reduce the condensation build up as suggested. I don't top it off for this reason. Gas expands when warmed up, fill to top in fall (cool outside) come spring gets warm out and fuel spills out the vent or gas cap. It's a mess and a fire hazard. <br /><br />I use non ethanol premium (hard to find in MN) and stabil. I have heard several times that gas looses octane but can't remember were and if a good source. Anyone know for sure?
red10
you can get it up north at alot of stations, look on the web and they list the stations that carry non-oxygenated gas usually its premium
POINTER94
KM2<br /><br />I experienced exactly what you described when I filled my tank in the fall and we had a freak couple of 90 degree days in April this year and the gas shot, no lie, 4-5 feet like it was coming out of a hose, from the vent and fill cap.<br /><br />Won't make that mistake this year...<br /><br />Red10, is there a web site you can recommend for gas stations with the non-o2 fuel?<br /><br /><br />Thanks
mattttt25
i've heard both sides, so i'm convinced it doesn't matter. add fuel stabilizer as directed and top off the tank next year before going out.
ZmOz
Yes, gas loses octane as it sits. That is a fact. Search google if you don't believe me.
swist
There are other issues. My boat has a 100 gal tank. I would rather not spend a lot of money to fill the tank so I can have a boatload of stale gas in the Spring that I have to put up with. It also weighs 600 lbs when full which is extra weight to deal with when towing launching in the Spring.<br /><br />I think I'd trust my water separator to deal with the condensation and leave the tank relatively empty.
zzub
There is a safty consern also, A full tank will burn and emty partly filled tank could explode due to fumes. Check with the Coast Guard & see what they rccomend ??
dingbat
I’ve got an 82 gallon tank and whatever is left in the tank after the last trip is what stays in the tank. I just stabilize and close the valves on the fuel tank and forget about it. Even with a ½ tank there is just not enough free space in the tank for condensation to make a difference whatsoever.
red10
km2 do a search on non-oxygenated gas in mn, there was a link that had ethanol click on that or msra
sangerwaker
Here's a link to Minnesota stations that sell non ethanol gas.<br /><br /> web page
crazy charlie
You are way off base with that one Dingbat.A half of a tank is plenty of room for condensation.If thats what you do then you better never forget to change your fuel water seperator or you will get stuck your first time out.Charlie
Scaaty
JEEEEZZZ...too much rocket science here. When you feel like getting ready to pull it out for the winter, fill it about halfway (or double whats in there with fresh) with enough Stabil to cover whats in there plus what ya add, run around the lake for 10 minutes, do what ya gotta do for winterizing, and tape/plug the damn vent up. Worked for me the last few decades. Gas cans in your shed are sealed, and you don't have them fill up with water do you? And I live in Puget Sound....we do get some drizzle here. And ALWAYS leave room for expansion (thats where the 1/2 tank come into play after taping off the vent). Does it not say that on every gas can made? And on losing octane, its basically the volitile stuff that disappears, and thats what creates the BOOM..gas don't burn, fumes do.
cc lancer
JEEEEZZZ...too much rocket science here.<br /><br />And the marina owners put $5,000. worth of gas in their above ground tanks to sit for 6 months.
