ccustomrides
- Mar 3, 2010
- 70
So I winterized last year and my boat made it with no problems here in COLD Michigan.
I service everything and fog the engine but I do use the 5 gallon bucket to flush the engine out.
Here is what I do and you tell me why people say to stay away from using this method.
I drain the cold block and exhaust.
I stick little screw driver in and get the gunk out and more water comes out.
I then start the engine and fill it back up with water again. Run it for few and then I drain it again. This in my book tell me it's flushed because second time there is no blocked drains.
Then I start the engine and run till my boat warms up all the way. I run till 150F or so.
I keep checking the thermostat housing untill it opens up and gets hot. I did replace the thermostat this spring and I know it works. Old one worked fine I just got a new one for a piece of mind.
So after it warms up I shut it down and switch over to RED POP from a 5 gallon bucket. I do use all of the 5 gallons and run everything out. With about one and half gallon left I start foggin and then shut it down for the winter.I DONT DRAIN THE POP BUT LEAVE IT INSIDE. NOW: I know it worked last year just fine but why does everone say to warm the engine up to operating temp and then drain the block and exhasut? By the time you do that Thermostat might close unless you remove it? Also 5 gallons is enough to push all the water out and fill everything up with Red pop in my 4.3.
Let me know what you guys think.
Thanks.
Thanks.
