Re: winterizing single point
Is there a sticky on winterizing single point systems?
Howdy,
In general, the "single point" systems can be problematic due to (normally occurring) rust flakes clogging the system enough to make you think you have drained the system when in fact the rust (and possibly) other debris blocks the flow of water still in the manifolds and/or block.
Then of course, you discover it next Spring, when you discover a "Spring" (pun intended) in the engine compartment.
The single point systems prevent (or make very difficult) poking a piece of wire or small screwdriver into the block and/or manifold drains to ENSURE that you have cleared the hole of ALL rust flakes to drain all the water out!
Convenience comes with a price.
I wouldn't trust a single point drain system unless the engine and manifolds were brand new...........and since even new raw water cooled engines start rusting immediately, I still wouldn't trust the system no more than 2 years or so before I removed it to ENSURE that the block and manifold drains were completely clear of obstructions!
So, toss a coin.... you might get lucky!
Good luck,
Rick
