winterizing
bosavy
the marina were i am at they do not me to use enthanol glycol because of enveromental impact.1 can i use the r/v stuff [which i already did] or just drain everything. it's a 5.7 liter i/o thanks
Re: winterizing
Ayuh,....... That's what I do,.......
Air just Doesn't Freeze.......
And,.....
It's Reasonably Non-Toxic..........
Don S
Re: winterizing
And,.....
It's completely Non-Toxic..........
Not sure I can buy that Non-Toxic comment, ever been to the big cities??? :p :p ;)
LA Smog
ziggy
Re: winterizing
thats what my phsycologist dad call the i gottya game bondo.......:)
bosavy, air is just fine. yer good to go. antifreeze is better for the anti corriosion features of antifreeze. my merc dealer sells me that pink rv stuff so it MUST be ok. same brand went thru -15*F last year. alledgedly environmentaly safe. i flushed what i used in the spring.....now he says he's usein merc antifreeze himself though. bulk. won't sell me any, whatever....... i think the key is gettin all the water out of the system. then yer hip either way......
dmcb
Re: winterizing
Just drove past LA and had to have the admiral go before the motorhome with a big knife to cut a path I could drive through.
Doug
Don S
Re: winterizing
What???? You sent her out in that???? Man, that's mean. Is she going to be ok after breathing that stuff?
dmcb
Re: winterizing
Well she won't drive the motorhome.
Doug
gene8084
Re: winterizing
thats what my phycologist dad call the i gottya game bondo.......:)
Do you run on the muffs to get the pink stuff in or are you pulling hoses and pouring it in?
ziggy
Re: winterizing
on my 165hp L6, i pull the t-stat houseing, then pour it into the block and the manifold......
Re: winterizing
OK Don,.......
I edited my 1st responce to take into consideration your concerns...............:D
Btw,......
Ayuh,.... I've been to the Big Cities, all over America....
Most of them several times,..... NYC, Many times.......
And,..... I liked LA the Least,..... Probably Chi-town the Best.......
From the eyes of a Trucker anyways........
Don S
Re: winterizing
OK Don,.......
Sorry, I just couldn't pass that one up :D
bosavy
Re: winterizing
i use muffs and a 5 gal pail of the pink stuff . i run it up to temp then drain all the water out of it then start and let the pink flow trough at the same time i install defog down the carb . thanks
Don S
Re: winterizing
That method works about HALF the time, do you feel lucky?
Better method is to drain everything completely, then dump in AF thru the T-Stat housing.
EDIT:
Oops, just noticed you said you DRAIN it first, then run the AF in.
