Re: winterizing
Severity of the winter doesn't really matter, it's the sitting and not running that you are really treating for, with the exception of the lower unit oil. Treat your fuel and run it for a while so you get treated fuel through your carbs. If you're using Ethanol than use Star Tron or something else specifically designed to treat the Ethanol fuel, double treat it for storage.
Fog it if you want, but it probably won't matter if it's only sitting for 3 or 4 months, can't hurt though. Change your lower unit oil and use new nylon washers on the fill and drain plug, spray the powerhead down with a coating of 656 and you're done. The hardest part is waiting to use it again.
