Mrcleaningguys
- Aug 7, 2015
- 46
I got a boat for free, basically. 79 century raven. Has a 165hp inline 6 engine. Did a tree job for a guy and he threw the boat in as part of the deal. It needed a new floor, gauges, and wires needed hooked up. Wires are all there, engine is wired, harnesses are good, I just can't make sense out of the harness running to the dash. I've spent endless hours reading hundreds of threads and articles trying to familiarize myself with wiring a boat, or rather boat gauges. But nothing I've read makes sense for this boat. I finally got my hands on a mercruiser stern drive repair manual and things make a little more sense now but the color scheme its still different.
The gauges I bought came on a dash plate with switches on it. All the gauges were still wired together and everything was ran to an 8 point plug. But the plug doesn't fit my harness and the color scheme is different. One at a time, I replaced a gauge wire with one from my harness. I also took off the blue light wires and purple 12v wires from ignition terminals. I will put them back but I needed room to work.
I believe I have my sending units and ground hooked up correctly. I'm left with a red/white wire, solid red wire, and yellow wire. Also there is a black/blue wire coming from my bow and stern lights. I've also ran a positive and negative from the battery. Positive goes to a fuse block. Negative goes to a separate block. There are 2 wires coming from my gas tank, yellow and red. And finally, there are 2 wires coming from my shifter, both red.
I'll post pics of what i have so far and hopefully someone can give me a Lehman walkthrough for the last few steps. Thank you.
