dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
1. Can the wire harness for 1995-1997 (could be earlier, since the engine had a mechanical fuel pump) Mercruiser 5.7 be rewired for the 2000 Mercruiser 4.3 Vortec Engine. I looked at the wiring diagrams and they are pretty similar. One difference was the fuel pump wire and the other was a different type of Thunderbolt IV distributor connector. The reason for this question is obvious - I have an engine wire harness for the older Mercruiser 5.7 engine and a newly rebuilt 2000 Vortec block with most of the accessories. I can install another rebuild engine 1993 4.3 Mercruiser, it has a harness and is complete, however, I got an almost complete accessories set for a newly rebuilt 2000 4.3 vortec engine without the wiring.
2. Another question concerning the same engine, I have a 2000 Larson 180 hull without wiring and drivetrain in excellent condition, that I am trying to rebuild. I got a complete Alpha One Gen 2 outdrive, transom plate, bellhousing and trim pump set. I have a dashboard to engine wire harness from 1993 Larson with 5.0L v8 engine. At the first sight it looks similar to the one I need, do you know of any differences between 1993 v8 and 2000 4.3 v6 Mercruiser dashboard to engine wire harnesses that need to be addressed?
Thank you
Thank you
