WIREING HARNESS
belkin
5 YEAR OLD 50 HP MERCURY OUT BOARD. WIREING HARNESS MAIN PLUG, ON THE STARTER SIDE OF OUT BOARD. NOT WONTING TO STAY TIGHT IN HOLDER.YOU SOME TIMES HAVE TO TOUCH THE CONNECTION TO GET THE KEY TO START THE MOTOR AND THEN IT RUNS GOOD THEN TIMES A BUZZER COMES ON STEADY TOUCH THE PLUG AND IT STOPS SOME TIMES IT WONT DIES OUT OR NO POWER .
Kenny Bush
Re: WIREING HARNESS
Take a little Dielectric grease and lube the harness mating ends. Also you should have a bracket that holds that harness to the cowling. Visually inspect harness pins to insure that none are bent, thus preventing the harness from seating properly.
