wireing terminale loose
MIKEY*2007
Hey guys last trip out my 1985 90hp lost power on and off got back and found that right side next to power pack the terminal block had come loose would this cause the earth to stop motor running properly as i have tightened it back up the motor ran fine on flusher but have not tryed under load and not sure if I should take it out on my own fuel is good bulb stays hard no leaks anyone know if this would cause problem
Re: wireing terminale loose
Ayuh,... I would think you've found yer problem,.....;)
MIKEY*2007
Thanks Bond o Happy New Year to you from the land downunder Mike.
