Re: Wireless Connection Problem
k, try something like this:
Open a dos command window (Start->run, type in "cmd").
In the dos command window, type ipconfig. A bunch of stuff should come up, you are interested in:
IP Address . . . . . : <your computer's IP address>
Default Gateway . . . : <your gateway's IP address>
Sounds like your router is your gateway, so the gateway address is the router's address. If you have no IP address, and/or no default gateway address, then you may be communicating on the wireless but you haven't been assigned a network address (and won't be able to get anywhere). Use start->settings->Network Connections, find your network , then "repair". That may help. If not, you should then log into your router (using a hardline) and check its wireless settings.
If you do have a gateway IP address - type that number into internet explorer as the url. This should bring up the router's configuration page. If you can do this - then you are on the network and communicating with the router. The problem is either in the router or a bit further down. So, log into the router and check it's configuration. (You did change the default password that it comes with, right? It's very easy to find the default passwords - someone else can 'take over' your router if you leave it). Some routers allow you to disable internet connections at certain times, or to certain computers/groups of computers. Check the settings...
-V
