Re: Wires smoking on my cmc pt-130
Wires only smoke when they are carrying too much current for their size. That could be poor wiring, but it is more likely an overloaded motor in the unit.
Check for binding in the mechanism, overload (outboard weight), binding in the outboard pivot mechanism or some other fault that is causing an overload on the pump motor.
It would be helpful if we didn't have to guess what make and model outboard you are tilting with that thing, too.
Good luck.
