Re: wiring a Mercury 4 stroke tach
Beck,
In your engine harness at the helm, you will see several individual wires, Purple is ignition power. Black is ground. Gray is tach sender. When you get your tach, terminate each of those wires to the appropriate post on the tach (you will see an S, I, and ground is usually the center stud), and you'll be good to go. Just make sure the "pole" setting is on the correct setting...
