Wiring a starter
Fireman115
Ok so I've been doing a total motor swap same motor just no cracked block. I have power to everything and now the starter just clicks. And my positive and negative cables get really hot. I was figuring I made a mistake wiring I'm going to add a picture of the starter and see if you all can see if it wrong. Please any help would be greatly appreciated. I took the wiring harness off the old motor put it on the new the exact same way, just not sure what's going on. Thanks in advance.
alldodge
The 2 larger red cables, one goes to the battery, where does the other go to?
Also what motor, and year?
Fireman115
It's a 94 Bayliner rendezvous not sure on what year the motor is as I bought it used. As for the other wires I'll have to look.
Fireman115
Oh sorry the motor is a 3.0 mercruiser the orange one goes to the alternator the yellow one I'm not sure unless I cut the covering off and follow it back.
Fireman115
Ok the yellow one goes to the relay in the other picture gonna attach it here too
alldodge
Want to know were the 2 "Red" wires go to
one goes to the start battery but where does the other one go?
I'm guessing but think the starter has an issue or the motor is locked up.
Can use a screw drive and jump from the yellow/red to starter terminal and it should crank if there is no issue with the starter
Do you know the motor installed is good?
Fireman115
One goes to the battery the other goes to a fuse. The motor shouldn't be locked up as I saw it run before I paid for it.
alldodge
ok thanks
Wiring is correct and cables getting hot because starter is not moving. Remove the starter and bench test
Fireman115
Ok so I have 2 starters and both work. So now I'm lost. Maybe try and get the motor to spin without pulling the motor again. I think I'm going to clean all terminals and try it again. Any other ideas would be greatly appreciated.
alldodge
You didn't happen to hook the battery up backwards maybe?
Fireman115
At this point maybe. I doubt it but just maybe. I'll look in the morning. I really appreciate your help alldodge.
