wiring aerator switch and recirc switch
ggrundel
I have a 2006 V hull tracker. I have 7 pin switches (one for each) aerator and recirculate. I know how to wire a normal 7 pin switch (7 =grd, 2/5 is power, 1/4 is position 1 appliance and 3/6 is position 3 appliance. But the aerator and recirculate go through the timer with red wires. not sure what wire goes where.
manual is position 3, pins 3/6 - I assume the appliance wires go to it. but not sure how the auto (position 1) wiring goes with the red ones coming off the timer.
auto is position 1, pins 1/4 is where I guess the red wires from the timer go?
can anyone help?
sam am I
I think I read correctly what you're saying and I've gave it by best shot, I don't have your boat's wiring obviously!...But, If close then this might help/get a start............Else, I can try to edit based on more info.
**Switches are center position off, pin 7's, main fuses/switch and the like are not shown as they are not in question**
