Wiring Diagram for a 1989 Wellcraft 192 Classic
cwoodard
Hi All, I am looking for a wiring diagram for a 1989 Wellcraft 192 Classic. Most of my wiring is unhooked/disconnected or cut. Thanks, anything would be greatly appreciated. I noticed that there was an older similar post but the wiring diagram given wasn't active at this time.
Chris1956
There is a common wire color chart which could be of some help. Maxrules may have something.
You could also check the Wellcraft website and see if they have something.
most of the wiring will be in the factory service manual for the motor.
the remaining circuits should follow the ABYC color scheme (in the electrical stickies)
alldodge
This is a V6 but same for V8 motors after 1989 and uses TB4 ignition
Being your rewiring everything you could go with newer ignition like Delco EST
The rest of the wiring
