Wiring diagram for simple fishing boat
WacoJ
Hi, I bought a 15' Gatortrax boat for use on a 200 acre lake. It has an 8hp pull start motor, so there's no need for a cranking battery. The trolling motor is a 12v, so there's also no need for 24v wiring.
However, I am adding a fish finder, voltmeter/usb charging port, and onboard charger - and a second battery. Additionally, the boat came pre-wired with nav lights, a bilge, and some led lighting that I also need to wire up. I mocked up the diagram below and would really appreciate it if anyone of the electrical gurus could give it a quick review.
Additionally, between the battery and the accessories buses, I was considering a battery switch, just to keep the voltmeter/usb charger from draining the battery when not in use.
mike_i
Looks good just be sure to use the appropriate sized fuses. Do you know how much current the trolling motor uses? I know nothing about trolling motors but hopefully the battery will have enough capacity to run it all day.
