Wiring help
nfisherman
Sorry. I’m trying to find out if the green wire should connect to the tan or tan/black wire. The green wire pulled out of the connector while is was changing the main harness and I don’t know which side to connect. This is on a 2000 Yamaha F115 TLRY. Thanks.
nfisherman
Who has a Yamaha F115?
The green wire in this photo pulled out of the plug on my motor. There are two wires attached to the top part of the connector but only the green wire at the bottom. The two wires coming from the top come from under the flywheel. I assume they have something to do with charging the battery. Could someone please look at this plug on their motor and tell me if the green wire connects to the tan or tan/black wire? Thanks
