bob johnson
- Feb 25, 2009
- 4,306
OK, I have three brand new Blue Seas Battery switches....they are for one battery each...I am going to run two 12 volt batteries and all systems on the boat will run on 12 volts. I don't know if it matters, but I have an onboard battery charger as well. I am THINKING I can the three switches and get the same results I would get if I went out and bought a new two battery switch. I am thinking one + line from one battery to the first on -off switch... and one + from the second battery to the second on-off switch. Then I would run the output from each to the input of the third switch, and the output of the third switch I would wire my motor and fuse panel to. I am not sure about one thing....if this set up would produce 12 or 24 volts if Both the first two switches were turned on at the same time....
my charger is a 2 bank 10/10 Guest Charger.
yes I am trying to avoid buying the correct battery switch...about $50......but Ill just buy it if my plan is flawed
thanks
bob
thanks
bob
