Wiring in docking lights
LegacyT
What size wire should be used to wire up a pair of 50W Halgoen lights. Innovative lighting says they draw 4 amps.
Thanks,
Mark
Georgesalmon
Re: Wiring in docking lights
4 amps isn't much even 16gauge is enough, though I would go with 14gauge its easier to work with. How far the run is counts. Might even go to 12gauge if over 20 feet.
LegacyT
I guess it would 4x2 so 8 amps total draw. There are 2 extra fused slots for accessories in the instument panel. Should I wire it in from there
Ayuh,... Use 1 of the fuse slots with a 10amp fuse, to yer switch, to yer lights with 14ga oughta cover it nicely,...
