carlosg
- Jun 21, 2014
- 11
Hi guys,
I have an old ’89, 16' Larson Runabout All American 5000, it had an 80’s Johnson motor and I replaced it with a 6cyl. ’82 ELPT Mercury that had been in storage for about 30 years. Well, the boat has gone thru many owners thru the years and today I’m doing some TLC on it and it has come the time to work on the electrical, after gutting out all the trash left over after each time someone worked on it I now only have the gauges coming to the front panel wired by my mechanic from the side control harness; I’m going to install a Combination Fuse and Terminal Block to which I plan to connect the following accessories (when I can buy them all):
Marine Radio
Fish–Depth Finder (got one who knows if it works)
Navigation Lights (original on boat: front and rear)
Radio-CD…?
Cigarette Lighter for connecting Cell Charger
Bilge Pump (installed)
Compass (bought)
Thus I think feeding the Fuse Block from the battery with an 8GA Marine Duplex passing thru a 20 AMP Push Button Circuit Breaker installed at the battery well (in rear) and at the front connect the 8GA to the Block with a lower amperage Fuse Holder:
Note: the bold underlined text has hyperlinks
Mod EDIT: The links have been removed. The forum server redacts competitor links. Please check the iboats online electrical section for those parts. If you find it priced lower elsewhere, iboats offers prive matching. Thanks
BTW: Lots of stuff is currently on sale as part of The Great Fall Sale. Plus they offer a discount to forum members so ask about that too.
Marine Radio
Radio-CD…?
Compass (bought)
- What size Fuse do I need for all my “accessories” draw?
- Can I connect the Fuse Block to the 8GA feeder passing thru a Fuse Holder with a smaller GA wire?
- From the Block I will wire all of the accessories mentioned above with 14GA, each with its own fuse: what size fuse for each accessory?
