wiring problem
jerkoz
am in the process of re-wiring my boat. the wiring under the transom was a real mess. wires spliced together with inline fuses. several pos. & neg. running to the battery. found out where all the wires go and marked them so I can run the wires from a fuse block with one pos. & one neg. running from the battery to the fuse block. the lights, horn and sump work but I have one set of wires that I don't know where they go. the motor is a evinrude outboard vro and the alarm is working. the wires are small ga. (like for a fishfinder). can't tell if it is for a elec choke. can anyone give a suggestion to where it might go. can't trace it once it leaves under the transom.
Barnacle_Bill
Re: wiring problem
That is pretty much impossible for us to know. Choke wires normally go into the harness then back to the motor.
