wiring problems - evinrude outboard 150hp/1989
ad
I took a negative wire and touched it to the positive wire on the trim gauage.<br />The lights went out and the switch stopped working while wiring up the lights on the trim gauage.<br /><br />Did it blow a fuse...where are the fuses located on the motor and ignition switch?<br />How can I fix my problem?
Bob_VT
Re: wiring problems - evinrude outboard 150hp/1989
Yes there is a fuse for the tilt and trim. There is also the possibility that you fried the guage. The fuse is usually located by the tilt solenoid in a rubber case. <br /><br />Bob
ad
Thanks Bob for solving my problem.<br />Your assistance is greatly appreciated!!!!!
