Wiring push button choke
gwoloshyn
1966 Evinrude Ski-twin here trying to hook up my starter switch with push button choke to the motor. So far the starter switch works but choke does not. Can someone tell me where to connect the wires from "C" on the starter switch, to the junction box solenoid and finally to the choke solenoid itself? My manual shows a separate choke switch but I will be using my new starter switch for choke. Thankyou in advance.
tx1961whaler
Re: Wiring push button choke
The C terminal on the ignition switch is wired directly to the choke solenoid
gwoloshyn
Thanks, I figured out I have a bad choke solenoid.
