wiring question
dcjcdc
have a 1990 sunbird corsica
with a 5.0 litre engine cobra omc inboard/outdrive
just noticed while hooking up my battery cables
there was one wire to put onto battery
( it is a brown wire than the wire turns into orange and there is a fuse with it)
what could this wire be for and does it go on the positive or negative on the battery
thanks
RWilson2526
Master Chief Petty Officer
Re: wiring question
any evidence of a previous installation of a fishfinder/chartplotter or radio? if there's nothing thats not working due to lack of power I wouldnt be in a hurry to hook it back up until I find out where the other end is.
Chris1956
Re: wiring question
That is normally a bilge pump hook up, on the positive battery terminal. It could also be some sore of impresssed current, anti-galvanic corrosion system, like the MerCathode system that Mercruiser has. You should trace the wire to see if my assumption is correct.
dcjcdc
Re: wiring question
bilge pump is working
- only thing not working is the trim guage
and was told its probably the sending unit
Chris1956
Re: wiring question
Very unlikely it has anything to do with trim gauge. See if you have a impressed anti-galvanc corrosion system.
wire2
Re: wiring question
If you have a multi-meter, check for 12v dc to ground on it. If zero, switch to ohms, check for resistance to ground. If it shows some, there's something connected to it.
Silvertip
Re: wiring question
Always hot wire for the station memory and clock on the stereo system perhaps. If it has a fuse in it it would go to the positive terminal on the battery. Otherwise, follow the wire and see where it goes. If the bilge pump has an automatic float switch, it would require a direct to the battery connection as well. So even though the manual switch on the console turns on the pump, the automatic may not be working.
JAL51974
Re: wiring question
+1 Silvertip.
What did it turn out to be? I am betting on float switch constant on wire.
Joe
seabob4
Re: wiring question
+1 Silvertip.
Joe
+2, especially since there is an in-line in it...
