wiring question
mrblue
In the proces of replacing wires in 16ft.tracker.<br />Its aluminum<br />Should all grounds run back to battery or can i <br />run a couple of main grounds from battery and connect other grounds to them.. I am running<br />sep. for trolling and fish finder. Just seems like alot of wires for lights,nav.lights,bilge,radio,acces socket,live well. Also TM is 40lb 12v and i got 8g wire and curious as to size of fuse or breaker i need.<br />any help would be appreciated.. thanks
18rabbit
Re: wiring question
Use a power distribution bar. Your vessel is on the small side but they are very common. There are several different manufacturers or make it yourself with 8” of electrical copper bar and stainless steel bolts/screws. Here is one:<br /><br /> http://www.iboats.com/mall/index.cg...ategory=electric>distribute&*******=987487640 <br /><br />Normally, there is one for each battery bank (+) and one large one that joins all the battery grounds (-) and all ground conductors . You can use a single, small one for joining just the grounds and have a single conductor going back to the battery. Except for the smallest of boats, the battery(s) should have only a single conductor to each terminal. In reality, people will not hesitate to connect everything directly to the battery.
newhewes
Re: wiring question
I have a MinnKota 55# thrust and the instructions call for a 50 amp manual reset fuse. Cabella's sells them for around 35.00. Deal wanted 68.00
