Re: Wiring Repair in quick silver throttle
paul frazer<br />You provided less than not enough information for a decent reply. Take the serial number of your engine to determine the year, and the assumption the control box is the same age to a Merc dealer and look at the different boxes to see if what you want is available. If the wiring harness is rotten, like a lot of '60s and '70s are, you may have to pop for a newer style box and harness. The inside the engine wiring is probably about the same shape,and you can spend big bucks fast trying to replace items in there. Then you can order a Merc manual for the project if you go ahead. Backfire
