Wiring Repair
Eric G.
I have a 2 inch piece of connected stranded wire that the insulation has been chewed off. Could I drip silver solder onto it and then paint with liquid insulation covering.
Silvertip
"Dripping solder" is not proper solder technique. For proper soldering you heat the metal and apply the solder to it. You do not heat the solder and drip it onto the metal -- especially an electrical connection. The proper fix would be to cut the wire in the middle of the bare wire. Slip two pieces of heat shrink tubing over the wires, twist them and solder them and then heat the tubing. Or if you don't like to or know how to solder properly, use a crimp type butt splice. If both ends of the wire are easily reachable, why not just replace the wire.
gm280
I second Silvertip's suggestions. Never ever drip solder on anything to solder something. That is asking for trouble. Replace the entire wire if you can, or use Silvertips suggest to connect them together. Do the job the correct way and you will never have to worry about it again. Do it the wrong way and happy boating out on the water where Murphy's law will have you stopped...
NYBo
Welcome to iboats!:welcome:
No need to solder the wire because the insulation is gone- that would only make the wire brittle and inflexible. Since it's only 2" long (a jumper between gauges?), just replace it.
Grandad
Just an aside. Be careful of the term "silver" solder. That's a different process than typical soft solder processes used in electronics. Silver solder is similar to brazing, done at much higher temperatures and is a method impossible to use on insulated wires. - Grandad
