Re: Wiring some spreader lights...
Appropriate wire size is determined by the voltage and current (amps) each light needs, relative to the distance between the light and the distributed power. Was that helpful?<br />
<br /><br />In a nutshell, you prob have 12v lamps, look at the manfs spec to see how many amps the light pulls, then check the wire-size chart, entering the length of the wire:<br /><br />
http://www.ancorproducts.com <br /><br />The wire calculator is under the [Technical Info] button at the top of that web page.<br /><br />Grommets are a darn good idea but they want to be mounted into a flat surface. If you will be drilling into aluminum pipe, they may not fit well. Also, rubber can age/crack/break rather quickly if exposed to uv.<br /><br />Alternatively, you can use some common, inexpensive rigid conduit. Have it bent then paint it before installing. Or use some non-metallic conduit like liquid-tite. It is very flexible, gray color, no problems with uv, 25-ft of 1/2-inch costs about $12 at Home Depot. Lots of options on how to attach it up under the top. Like UpNSmoke said, Id angle the end fittings down to prevent water from running up into the conduit, tho it wouldnt hurt anything if water got in if you use liquid-tite.
