Wiring Trouble
xtreme872
Cranked the boat the other day and the motor turned over and burnt the hot on post on the battery and melted the lead around it... Any idea on where to start... Short etc..
mkast
Re: Wiring Trouble
Disassemble and clean both ends of the battery cables.
Better yet, replace with some larger cables.
danond
Re: Wiring Trouble
Replace the cables and test again. If they burn up again, you have a solid short somewhere. Probably starter.
xtreme872
Re: Wiring Trouble
Same cables that came on boat its a 1999... I guess the cables could be getting old huh?
dontask
Re: Wiring Trouble
It could have been a poor, loose, corroded connection right at the post. Just replace the terminal end with a new crimped terminal post connection. Or replace the one complete cable & make sure its tight and clean. Do not waste your money on those cheap fix it battery terminal lugs with the bolt down clamp for the wires. Resistance at the post to the cable clamp is what most likely caused the heat and melt down.
mkast
Re: Wiring Trouble
Boat manufacturers install notoriously small battery cables.
Small cables have more resistance. More resistance, more heat.
If either end of either cable is loose or corroded, more resistance, more heat.
Re: Wiring Trouble
Nope,... The Positive Terminal was Dirty,...
That causes resistence, which causes Heat, which melted your battery...
180shabah
Re: Wiring Trouble
After replacing the battery and cables, buy a wire brush and keep the connections clean.
