boatingmark
- May 17, 2015
- 89
Does anyone know if am i able to lift my 280 out drive up out way manually and somehow lock it, i need to do this so i have clearance when removing the boat from the water on a slip way, i really dont want to risk scraping the outdrive on the concrete floor!!
Perhaps lift it up by hand and use a piece of wood? Would it hold ok? Maybe even tie it up onto the swim deck?
This is obviously just a temporary measure so i can repair the u joint bellow and hopefully investigate and fix the tilt issue!
Not sure how to go about it!!!
Thanks in advance!
Thanks in advance!
