Wizard trolling motor prop
Al Saufley
Have a wizard battery powered trolling motor (model ESK6974B97)that I need a replacement prop. Measures approximately 5 1/4” , 1 inch diameter hub, 2 blade, held on shaft with roll pin. Shaft measures .3” with calipers. Anyone have any leads on contact info for business that may have this. Thanks!
MOD EDITED TO REMOVE SOLICITATION
gm280
First thing first, welcome to iboats. Always great to have a new member join us...
Okay an older trolling motor for sure. What is wrong with the prop you presently have? And can you post a picture or three of it so we can get a better idea what you are dealing with. If you can't find one that is an exact fit, you can always have an adapter made to allow some other prop to fit. Most any machine shop could turn one out in a few minutes at best. Or if you find a suitable prop but the prop shaft hole is too small in diameter, you could have it drilled out. Just some ideas if you can't locate an older prop for it.
Al Saufley
Thanks for the reply. The prop blade and part of the housing is broken off on the one side (plastic). See pics attached. Any thoughts?
gm280
Well that is surely not going to work. However, maybe you could find someone in your area that has a 3D printer and design one and print it out. That would be a great 3D project. Other then that, you can look at some newer trolling motor props and see if any are close to your broken one and modify it to work. Look at the lower trust TM models and even the manual smaller version TM's may have something that could work. There is always a way...
Al Saufley
TM’s??
