Won't crank
rdtoli
1973 johnson 115. <br />model 115ESL73M Serial 1388075<br />My engine won't crank. Have replaced coils,<br />starter and solenoid. Had running and would not shut off so took igniton swith apart and touched black w/ yellow wire to 2 black ground wires and sparks flew and it shut off. Now it wont do anything. Was told to check in line fuse replaced it still nothing. Could it be the power pack if not what could it be. Woould it make a difference if there is no brass bolts between wires on solenoid. Thank you
walleyehed
Re: Won't crank
I would highly recommend a manual for that type of trouble shooting because you may have burnt out your stator, rectifier, and who knows what all. spend 30-35 bucks on a manual and save yourself hundreds.......that electrical stuff ain't cheap.
KennyKenCan
Re: Won't crank
You definitly need a manual for that motor.<br /><br />Hate to tell you this, but you may have fried alot of expensive parts using the trial and error method.<br /><br />Kenny
rdtoli
Re: Won't crank
Ok don't know if this make much difference or not but you can cross out the solenoid and it will crank. Think i will order a manual but in the mean time thanks for all the help.
KennyKenCan
Re: Won't crank
Yeah,<br /><br />It will crank, but with what you told us so far, it sounds like you may have caused more damage by not following procedures that are outlined in the service manuals.<br /><br />Not trying to get on your case or anything, but an outboard motor is not a Chevy, and fooling around with things without knowing the procedures is just going to cost you more $ down the road.<br /><br />Kenny
