Just purchased an '87 Ebko Marine Monte Carlo 16' with Mercruiser 2.5 L and Alpha One. Went to lake today (owned boat 2 weeks now) and wouldn't go into gear. It just made a strange wizzing wining spinning noise, no prop movement. Need some help.
Doesn't sound good my friend. 2 places to start looking. <br /><br />1) Spline in the bottom of the upper drive shaft is stripped (usually rusted out).<br />2) Lower drive shaft is sheared above the water pump.<br /><br />Good luck (you may need it).<br /><br />Chris..............
My shift controller is REALLY sloppy, may have put it in reverse when I thought was neutral (didn't notice any loud sound or "shimmy"), would a slppy controller cause the broken part?
